One camera remains offline
One of four cameras is off line and I can’t get it back on line. I have tried reinstalling it but it is still off line. I have tried resyncing it, changing batteries, but no luck. What am I doing wrong?
You are probably not doing anything wrong. I'm going through the same thing with one of my Pro cameras. The idea of this product is a great one. Unfortunately, the product itself is not great. My complaints about lag time, connection issues, etc., etc., are the same as everyone else. 10 months into my purchase I will now start the battle over a return/replacement as I have spent way too much time trying to make it work. Connect,reconnect, remove, add, delete, upgrade, rinse, wash, repeat.
Looks like I'll have to bite the bullet and install a real wired system.
Did you try removing it and then re-adding it? Or did you just resync?
Multiple times via iOS and Browser. (Chrome and Edg
Eufy looks promising.
I did on Saturday. Have not heard anything yet.
Hi @jfcoll
I have escalated your case #41159653, customer support will be reaching out as soon as possible. Thank you for your patience.
Never heard from anyone. I've pretty much given up this product.
I really liked the idea of wireless battery powered cameras, with a magnet. Too bad they don't work. When I say they don't work I mean even the two that power on and record do me no good when the recording doesn't start for 5-10 seconds. There is no peace of mind with this product. These devices are advertised as security cameras. I don't feel very secure with a camera that starts recording after the bad guy is in your home. We can only hope it would get a recording of him leaving.
