One camera will not send notifications of motion to cloud or phone. Two other cameras are fine. I have turned on/off several times and re-synced
8 REPLIES 8
Camera is picking up motion but not sending or recording
Can you make a manual recording?
Never tried before but it was successful.
Ok. Are you using the "armed" mode, or have you created a custom mode?
Have you tried the motion detection test to confirm that the camera is picking up motion reasonably well?
Motion detection is working and it is in armed mode. No custom
Smart subscription? Or basic?
Smart subscription and updated app
How are the notifications set up? Are you filtering out "all other motion"? If so, try enabling everything.
