How do I change the sound of push notifications on iPhone 6s. This is a security system so clearly you should be able to make the sound more audible. I want it to be a sound that will wake me up in the night. These cameras are useless without it.
On android in settings you can change the sound notifications, don't believe you can in IOS...
Either way, the push noises are only as loud as your phone and may not wake you up.
BUT, your system does have a siren which you can set in the Modes by schedule or use at night... if that doesn't wake you up , not much will
I don't want to wake the entire house up. Also the base station is really far from my bed. It just seems like such a simple and necessary function. The app itself if lacking so many options that most security cameras have.
