I am not receiving push notifications as of 4/2/20. I have done a factory reset on the base station, I have changed the chime noise, I have uninstalled and downloaded the app, cleared the cache, forced stopped the app, literally everything. Still no notifications. It will record and the videos are in the library, but I don't receive any notification via the app at all.
Hi ckeepers16,
What phone device are you using? What Arlo app version are you running on your device?
When reinstalling the Arlo app, have you tried rebooting your device to see if that helped? Have you checked your Galaxy S9+ settings to see if you have the notification is enabled? Make sure you also don't have Do Not Disturb on.
I would suggest to contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
