  • 9 Replies
  • 3606 Views
  • 2 Likes
lovegoldens
Recently, the format on my Arlo app changed on my phone. Instead of just asking to arm or disarm, it now says arm away, arm home or standby. I don't remember asking for an upgrade. The old way was working just fine. I can access the cameras through my phone but I cannot receive motion detection notifications even though I turned on motion detection. What is going on?
@lovegoldens wrote:
I am getting motion triggered recordings but am missing notifications. Do you have any suggestions?
There are two KB articles that have troubleshooting tips for this - one for iPhone, one for Android.
But instead of just checking the rule in the mode(s) you are using, I suggest deleting all the rules in Arm Home and Arm Away, and then adding them back.  If that doesn't help, then proceed with the other steps they suggest.
9 REPLIES 9
It's not an "upgrade".  Arlo re-engineered their user interface a couple years ago, and has gradually been migrating folks using the old interface to the new one.
What mode is the system in? (Arm Away, Arm Home, or Standby)?  Standby should be the same as "disarm".
You can see the current mode on the dashboard screen.  It is shown in color, the other two are gray.
lovegoldens
Arm Home but I have also tried Arm Away. I have set it for motion detection but I am not receiving notifications.
Can you make a manual recording while livestreaming the camera?  Then see that recording in the feed?
lovegoldens
Yes. I can. It works that way. I just cannot receive notifications. I am just wondering if I need to do something else.
Are you seeing motion recordings in the "Feed"?  Or are those also missing?
(Sometimes people get recordings w/o notification).
lovegoldens
What do you think is the problem?
Again, I do not know if you are
  1. missing both notifications and motion triggered recordings
  2. missing notifications but getting motion triggered recordings
Next suggestions depend on understanding this
lovegoldens
