Hi,
since a couple of days I have the problem that everytime when I open the Arlo App on my iOS Phone or iPad one of my cams has a noise detection.
I have 4 cams and the noise detection with notification is only activated on this cam. The room where the cam is located is completely quiet for sure.
The test procedure is pretty simple.
- Opening the app
- just wating a few seconds
- The message „Noise detected“ appears
this can be repeated in an endless loop....
anything I could do?
Thank you!
Have you tried to reboot your base station & reboot your camera by removing & re-inserting the battery?
Thank you for your answer!
At the moment I cannot easily do that because the station is in a vacation home. I‘ll try next month, in the meantime I have disabled the noise detection....
You can also try & reboot the base station within the mobile app or website. The only downside is, if for any reason the signal is lost, you will be away from your home to troubleshoot.
Hi @Mbengson
I have a few questions for you
-What Phone/Device are you using when you experience this?
-What IOS/App version are you running?
-What cameras and base station are being triggered?
