After we downloaded the new app no recordings in our library
did you try making a manual recording to see if that worked?
Also, did you try using the web interface ( https://my.arlo.com ) from a PC, and check for recordings there?
I’m having this same issue for the past couple of days. I can trigger a manual recording and it does show up in the library and I can also run a motion test and the LED indicates that it is seeing motion.
I have another Arlo Pro on my other door that is behaving exactly as expected. It’s just this camera.
Have you tried to reboot the camera or remove from Settings > My Devices > Re-Add them?
