What prgm did you use to play back d/l vids.... one of the better ones ( free ) is VLC
allows frame by frame,, slow motion, snapshots, and audio
Thanks but used VLC, Magix, Premiere and Windows Media. Audio track wasn't on any of them.
Were you able to check the metadata info ? audio listed?
I would report the issue to Arlo support... first I've heard of it.
AGreed. If the library has audio, so do the downloaded videos since they're the same thing. My first guess is audio turned down or muted or something in the computer not working right. If you use a different computer (use a thumb drive to transfer if needed) do they work tehn?
Have you tried reinstalling the app from your Android phone to see if that helps? And have you tested on other phone/tablet devices (if you have any)?
