No HD, Arlo Pro Smart Security System (VMS4330)
Why is my Arlo Pro not playing/recording in HD? I bought this system because I need a real HD security camera, but on the "Best Video" setting I cant even read a license plate from 10 feet away.
The Pro is 720 ( and yes the low end of HD ) but also wide angle of 130d...
It was not design to pick up plates which does require some special requirements ..esp if moving
great so I have 130 degrees of not HD. this is a license plate....at 9.1 feet. your telling me that this is marketed as an "HD" cam that cant read a licensce plate at 9 feet while not moving. but its suposed to be a security cam. a security cam that cant read plates, really dude?
Apparently you don't understand the technology and the implementation.
720p is <1 megapixel. My first digital camera had similar resolution back in 1996. My 5 year old digital camera has 21 megapixels. Which one is going to show more detail? 1080p is still only 2Mp.
130 degree angle of view is roughly equivalent to a 10m fisheye lens in 35mm camera-speak. Download an image from the Internet from a fisheye lens and try zooming in on it.
And then there's the compression which lowers the apparent resolution. I do have an issue with how much compression is used in these cameras but until something is changed it is what it is.
