Every time I try to add my new iphone 13 pro to the arlo app it says "There was a problem trusting this device. Try again." I have tried everything I can think of with uninstall and re-install. Deleting the app off my old phone. Anyone else have this same problem?
This issue has been resolved. Please authenticate and attempt to trust your new iOS devices again and let us know if you still experience any issues.
Thanks,
If you go onto the arlo web portal you can choose another method such as email to receive the request to trust your new phone.
I am having the same issue. I’ve deleted/reinstalled the app, restarted the phone, deleted the old phone as a trusted device, tried both SMS and email for the 2-step verification process and NOTHING works.
I am seeing the same thing. I am using a replacement iPhone 7 as my old iPhone stopped working. I restored the old phone to the new one from a backup. Arlo wouldn't trust the device. I removed the old trusted iPhone, reinstalled the app several times, cycled power to the base station. Nothing seems to allow the new iPhone to be trusted. There seems to be no way to get past the trust device stage.
https://kb.arlo.com/000062580/What-is-a-trusted-device
I just got the iPhone 13 Pro, and having the exact same problem as you describe. Every time I try to add my new iphone 13 pro to the arlo app it says "There was a problem trusting this device. Try again." If anyone has a fix, kindly share. Thanks in advance!
I've escalated this topic, we're currently reviewing reports of this issue and will provide an update once we know more.
So frustrating!!!
Same issue. I can't get the app to trust my new iphone SE.
I've tried all of the above suggestions.
Not working.
I figured it out!
When the app asks you to "trust this device" you have to click "Don't trust" and then it instantly started working.
Yes!! I tried that out of desperation and it worked!! Just signed in to let others know when I read your reply. It is counterintuitive to say DON'T trust this device, but I am just happy it's working!!😀
Thanks,
