  • 7 Replies
  • 3463 Views
  • 5 In Conversation
NIckAtNight
Your Case Number Is: 27851335
New ARLO pro 4 camera setup. Been working fine for 7 days. Cameras were fully charged and were not reporting low battery.
Attempted restarting ARLO base station several times.
Cameras will no longer connect.
7 REPLIES 7
NIckAtNight
Other remotes NEST and HUE still appear to be functional.
steve_t
Master Master
Go into the arlo app and remove all of the cameras. Reset the base. Reset all of the cameras with a battery pull. Try add the cameras again
If you reset the base, you'll have to start fresh, removing all devices in Settings, My Devices and then use the Add Device button on the Devices tab to add the base back in, followed by syncing the cameras.  You can try power cycling the base, open and close battery doors, removing just the cameras and resyncing so you don't lose any customizations.
NIckAtNight
No reset. JUst attempted restarts.
NickAtNight,
Were you able to resolve the issue through your open support case? Please let us know.
Plugplug1
Not able to receive cameras on phone 7s edge need help
Plugplug1,
What do you mean by "receiving the camera"? Are you having trouble syncing? What is the LED behavior on the base and the camera when attempting to sync? Please give more details about the issue you are experiencing?
