  • 2 Replies
  • 1768 Views
George_34
Camera’s who  connect with Netgear VMB3000 Basestation can also connect with Arlo Basestation VMS3330 ?
Some confusion here, as the VMS3330 is a system sku, and not a base station model.
It is an old one, and if you are purchasing used then you should be aware that it is end-of-life.  Also, if the original owner didn't think to remove the equipment from their account before sale, then you will not be able to on-board the base or cameras.
That said, bases are backwards compatible, and the VMB3000 was the first base.  So any camera that connects to it will connect to any base.
George_34
Thank you for the answer 🤝👍
