Need a wireless device that will activate an alarm/siren when motion is detected
  • 2 Replies
  • 971 Views
CCinPA
Need a wireless device for my 48946A7EAF99D that will activate an alarm/siren when the wireless motion-detected is tripped... Help?
brh
@CCinPA,
I am not sure what a 48946A7EAF99D is, but if you are looking for a device that will sound a siren and/or trigger a camera to record a video, there are several systems out there that will do that for you. I am using Samsung Smartthings. Any sensor connected to Smartthings can both set off a siren, including the siren built into the Arlo Pro base, and start a video recording.
Brian
michaelkenward
Sensei Sensei
Sensei
@CCinPA wrote:
Need a wireless device for my 48946A7EAF99D ...
What's a 48946A7EAF99D?
Looks like the serial number of something. Camera? Hub?
If you have an Arlo system, and a hub that contains an alarm, you should be able to create a rule that turns on the alarm when something senses movement.
So, what Arlo stuff do you have?
Just another user
