Need a wireless device that will activate an alarm/siren when motion is detected
Need a wireless device for my 48946A7EAF99D that will activate an alarm/siren when the wireless motion-detected is tripped... Help?
I am not sure what a 48946A7EAF99D is, but if you are looking for a device that will sound a siren and/or trigger a camera to record a video, there are several systems out there that will do that for you. I am using Samsung Smartthings. Any sensor connected to Smartthings can both set off a siren, including the siren built into the Arlo Pro base, and start a video recording.
Brian
@CCinPA wrote:
Need a wireless device for my 48946A7EAF99D ...
What's a 48946A7EAF99D?
Looks like the serial number of something. Camera? Hub?
If you have an Arlo system, and a hub that contains an alarm, you should be able to create a rule that turns on the alarm when something senses movement.
So, what Arlo stuff do you have?
Just another user
						Apple HomeKit1
						Arlo Mobile App449
						Arlo Pro27
						Arlo Pro 21
						Arlo Pro 32
						Arlo Secure1
						Arlo Smart102
						Arlo Ultra1
						Arlo Web and Mobile Apps6
						Arlo Wire-Free10
						Before You Buy1,206
						Discovery1
						Features237
						Firmware1
						Firmware Release Notes119
						Hardware2
						IFTTT1
						IFTTT (If This Then That)48
						Installation1,430
						Installation & Upgrade1
						Online and Mobile Apps1,266
						Partner Integrations1
						Security1
						Service and Storage563
						Smart Subscription1
						SmartThings39
						Software & Apps1
						Troubleshooting7,335
						Videos1
