I have one working camera I switched some problem and it is also doing it with my security light
A few more details would be useful. It's not exactly clear what you're describing. Do you have more batteries to try or more cameras or lights? Are the batteries totally depleted? If so, check out the FAQ here to attempt to rejuvenate dead batteries that don't seem to want to recharge.
It may be faulty batteries or cameras so we need to figure out what's going on. More details are better.
It’s a default battery ! Same thing happened to me
One issue I figured out with there help is I had two identical white charging boxes and the one with the lightning bolt worked, but I also have two identical white cords and one works and the other does not
You need the original ac adapter and cable or the battery will not charge ( it's a dual voltage adapter with 5v and 9v to charge )
