My Arlo camera continues to go off without any visible movement??
  • 1 Reply
  • 699 Views
Spencer17
Camera keeps going off without visible movement
Is this a new installation (or camera location)?
One possibility is that the movement is gone before the camera wakes up/starts recording.
Another is thermals (wind) - they can sometimes cause a temperature differential.
Have you tried lowering the motion detection threshold?
Also, if your camera supports audio detection, make sure that is turned off.
