My Arlo Pro Wire-Free camera won’t sync with the base station; what do I do?
  • 18 Replies
  • 25251 Views
  • 8 In Conversation
iannmel
HI Fellow Arlo users,
Just purchased a brand new Arlo Pro combo with base station and 3 cameras. With the base station connected to the net  and powered up (green lights OK). I then tried to sync one of the 3 cameras with the same result. Unable to sync any cameras.
The sync light flashes on the base station when pressed for the 2 secs, then pressing one of the  cameras sync buttion for 2 secs, the blue light flashes slowly. After a period of approximatley 30 seconds the amber light flashes fast on the camera, and the green light on the base station extinguishes itself. Help please......not a happy customer presently
iannmel
Hello All,
Ive had success this morning, after powering the system down for an entire day it now works perfectly.?
Cameras have update there firmware settings as did the base station.
Not quite sure it finally worked, but thats electronics for you.
Thansk to too all your inputs for my dilemma
regards
ian
18 REPLIES 18
Streak2
Master Master
For good measure, factory reset the base using a paper clip, hold in until all lights turn amber.
Then begin the process from scratch.
You only need a momentary press of the sync button on the base.
cwasea
Is the camera charged?
iannmel
Hi Prodigy,
Ive completed the tasks,unfortunatley they havent worked. Seems to effect all cameras with the same result.
I have now made an decision to strat charging one camera and test after the battery is fully charged. Netgear report
there batteries are fully charged although perhaps not enough to transmit across 2.4 adn 5ghz. Time will tell.
Otherwise its back to the retailer for a refund/replacement.
iannmel
It appeared charged without any indication of battery failure. I will therefore endeavour to charge 1 camera , so i can eliminate this from my fault.
cwasea
I read the fully charged comment from the factory statement too. Finally plugged it in to charge and it finally synced.
You can also try syncing while plugged in.  The camera will run fine on just the power supply.
iannmel
Ive tried various tasks,Reboot,power cycle moving base away from router, camera fully charged, also camera fully chraged and plugged into power supply. Still no sync.
I've tried a base station factory reset , now we have solid green lights on the power, internet and a Solid AMBER light on the camera led.
Tried syncing again and no sync available, I need my money back grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr
iannmel
Base station will not sync even with camera plugged in grrrrrr
Sounds like a faulty base. Either swap the system at the store or open a case with support using the Contact Support link at the bottom here.
iannmel
Hello All,
regards
ian
Streak2
Master Master
Good job Ian.
Well done for persevering and thanks for the feedback.
bonrab21
when I plug it in to the charger nothing happens  no blue light
bonrab21
how do you know it is charged ?
bonrab21
I tried this and it still did not sync
bonrab21
same with me   grrrrrrrrr  I will be really upset if they try to give me a 15% restocking fee!
bonrab21,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
Gmang
My cameras wont sync with base
brh
@Gmang
Here is a link to an article on how to troubleshoot your problem.
https://kb.arlo.com/000039094/My-camera-will-not-sync-with-the-base-station-how-can-I-troubleshoot-i...
Brian
