My Arlo Pro Camera suddenly stopped charging 2 years of usage. Can you please suggest how to fix this.
If you don't have another Pro camera to swap batteries around, make sure the charger and cable are the proper ones and have no damage. You can also try a different charger that has both 5v and 9v outputs such as used on recent phones as well as a different, quality cable.
