Just stay blinking blue all day not syncing
I've found this is typically due to interference. Try moving your base station a few more feet away from your router or restarting your router to get it to change channel or manually change the 2.4GHz network channel. Then try sync
Hi Fern4444,
Here is a link to help with the syncing process to make sure we are getting the sequence correct.
My camera will not sync with the base station; how can I troubleshoot it?
