I've been having 3-4 videos created from both Pro cameras but only one motion event. It's not that the motion continues but the cameras seem to think so. It only happens at night - daytime has been fine. I use high sensitivity and have been slowly reducing it to see what happens with no luck. Anyone else? If so, have you fixed it? How?
Since I'm not the only one, I'd suggest that anyone having this issue should open a case using the Contact Support link at the bottom here.
jguerdat,
Thank you for bringing this to our attention. I have not seen this behavior. I will escalate this topic for further investigation.
Case #27613347
UPDATE: After doing some testing in a closed/dark eviroment (during testing I discovered some permanent noise/sound on the recordings) I will get a replacement this week.
