Is there a way to have multiple modes for example I have my system on Schedule Mode for all cameras, but would like one camera to be armed at all times?
@UONT2 wrote:
I tried to create a custom mode for camera A, but as long as the mode selected is Schedule it doesn't work. I can't find a way to have the Schedule mode selected and the camera A mode on when the Schedule mode has the camera disarmed.
TURN off Schedule... crate a custom mode for A, then Schedule the new A mode and armed for time wanted.
READ the FAQS:
https://kb.arlo.com/1145394/How-do-I-create-a-mode-for-my-Arlo-Pro-Wire-Free-camera
https://kb.arlo.com/1012275/How-do-I-configure-and-use-the-Schedule-option
Only one mode can be active at a time...
But you can easily have 1 of 3 cameras active 24/7 by splitting up the cameras you have with a custom(s) mode.
exp;
you have cams A,B,C and want A 24/7 but B & C only from 7am to 5pm
Create a custom mode for A by itself, and use the Armed mode for all 3 during 7am-5pm.
then schedule A for all the other times
Do you have to manually change the mode from home to away modes?
READ the FAQS:
That workes.
