Arlo Pro on Verizon Jetpack® 4G LTE Mobile Hotspot
We recently purchased the Arlo Pro. The WiFi we have is
Verizon Jetpack® 4G LTE Mobile Hotspot. We purchased the
Wireless Wifi Bridge Dongle, LinkStyle Wireless Bridge Cable Convert RJ45 Ethernet Port to Wireless/WiFi Dongle, 300mbps, Plug & Play High Power Wifi Hotspot Extender Amplifier
- Wifi Enabled: Provide Wireless solution to network connection building without network cable.
- Wide Usage: Works with any network enabled device - TV, DVR, game console or home A/V device with Ethernet port.
- Support 2.4 GHz WLAN networks, 300Mbps rate of transmission. Also support WLAN security with WPA2, WPA and WEP (128/64)security access
- No Driver and System Operation Requirment Needed.
We cannot get this Wifi Jetpack and WiFi Bridge to connect so that we can use the security camera.
Can anyone please assist?
Thank you
sounds more like a Verizon issue over Arlo... good luck, and fell free to share with others what the issue was to assist others
