Movement
- Is the only way to get movement on your camera now is through a subscription?
Nothing has changed there.
But something appears to have broken in the Arlo cloud. Other affected users have said that
- removing the base and cameras from their account
- resetting the base with a paper clip
- adding everything back to their account
fixed it for them.
The mods ( @BrookeN ) might also be able to do something on the Arlo end.
@Blm3 can you watch it through out the day and see if that behavior changes then let me know. I have synced the account using our back-end tools and that generally fixes the behavior you are seeing.
