Motion sensor adjustment not work
  • 1 Reply
  • 2544 Views
cl1982
The adjust meant for motion seems to not be working. The camera used to work properly. I had it mounted and it would only pick up motion a certain amount of feet away. Now I mount it back up and it keeps catching the cars from the street which was not the problem before. I adjust the motion setting but it doesn’t make a difference.
Are you changing the setting in the rule?  The setting in the motion detection test is only for testing.
I've found that adjusting the camera position is better than changing the threshold.  Shifting the camera downwards can help even if the street is still in the video, since the camera is most sensitive to motion at the bottom of the field of view.
If you have a subscription, you can also set up cloud activity zones.
