  • 1 Reply
  • 539 Views
srkinsman
None of my 4 Arlo cameras are triggering the alarm when detecting motion. I ran the sensor test and they seem to detect motion just fine, they just aren't sending notifications or recording events. Seems like lots of people are having the same problem.
If you read through the posts about this issue you would see a likely solution. Remove all devices from your account and add them back, starting with the base, as if new.
