  • 7 Replies
  • 4005 Views
1775USMC
I get motion alerts once in awhile. Ive noticed my motion icon stays on but no alerts.. Ive turned cams on and off.. Still.. Any suggestions..?
7 REPLIES 7
What devices are you using android, ios, phone ?
1775USMC
Android
Two things off the bat, and fairly harmless/easy
unplug and replug in the base,
uninstall and reinstall the app
1775USMC
Ok.. Thanks TomMac.. Ill do it tonight..
1775USMC
Btw do i need to sync the cams again when i reinstall the app or will it just pick up?
The app if uninstalled will make no difference on the cameras sync'ed to the base... so just reinstall app ( enter name/pw )
Remeber that the app really acceses the Netgear servers, not the cameras or base directly.
1775USMC
Thanks again..
