Motion box unchecks on its own and the alert box goes away
My iOS is up to 10.2, so perhaps you should consider updating? The app for me has been quite reliable, but if ever something wonky then I just reboot either the Arlo base, my phone, or both. Usually resolves whatever hiccup there might have been.
I've always done it from within the app under settings > my devices. Choose your hub and there's a "restart device" button near the bottom.
A new version of the Arlo mobile app has been release for iOS (2.3.2). Please visit the app store and download the update. Are you still seeing the same behavior?
src81,
I have tested this and I am not able to replicate the issue you describe. when adjusting recording length in the iOS app, you must press, hold and drag the slider to adjust the recording length.
Could you provide a screenshot of the issue?
