Camera is set for the driveway.
Motion detection will not activare until I'm pretty close to it like 5 feet.
I notice my signal strength its a very poor.
Would that be a reason why the camera does not active at a farther distance ?
That's a good place to start. Try moving the base to see if you can get a better signal. You may need to reposition the camera, too.
You could use a WiFi extender to help move the base to be in a more optimal location.
