I seem to be able to get motion alerts from only one Arlo Pro camera per Arlo Pro Base at a time. I have a few cameras per each of three bases. Is this a fixed feature, or should I be able to get alerts from more than one per base?
You should be able to get multiple videos at one time. Each base can stream 5 cameras at once although your Internet connection may not support that much without Arlo dropping resolution due to the throughput issue.
