I apologize if there is already a post about this, I tried searching and I could not find the info
I'm trying to setup a camera mode so that if Camera A detects motion, Camera A AND Camera B start recording. I created the rule, If Camera A detects motion Record on Camera A. Next I added an additional device Camera B and saved everything. I tested and neither camera recorded me walking through Camera A range. It seems pretty simple to setup, but for whatever reason it doesn't record.
has anybody else seent his issue? or maybe i set something up incorrectly?
I suppose this is a dumb question but did you select the new mode to be active? Are the running men for the cameras in the Devices tab black or gray?
I was under the assumption that if I could create a rule and have multiple cameras record from that 1 trigger point (Camera A)
When creating the rule the app allows you to add additional cameras and asked what you'd like to do. IMO, if you can't do that, then the rule shouldn't allow you to add additional devices.
JoBu-NY,
When creating a custom rule for your camera you can add multiple devices to the rule to achieve what you're describing.
From your original post, it sounds like you've done this correctly. After selecting the custom mode, what color are the running men on the devices screen? (black indicates the camera is armed and ready to detect motion, gray indicates disarmed)
They are black, i double checked everything the other day and everything was set to armed.
