Is there any way to mix wired and wireless cameras with the arlo pro base station?
I have a wired Arlo Q and want to get a Pro also - possibly two. Can I see the images from all cameras on the same app and computer interface? Will they just count as different devices? Will recorded views from each all show up in the library?
One other question - I have set different view zones for my Arlo Q - can I get recorded footage from each view? If not, what is the point of zones? Thank you
1) Yes, all cameras will show up in the same login as long as you just add the new cameras to the same account using the Add Device button. The limit is 5 cameras in the free plan so you're all set.
2) The Q zones are for defining where motion is detected which limits false detections. You can also use Pan & Zoom if you want to crop the recorded view.
