  • 5 Replies
  • 18013 Views
Drocks523
What is the maximum height on the outside of your house recommended to still get maximum functionality out of the motion detector and voice
Retired_Member
Not applicable
Drocks,
I recall NETGEAR having a position on this. Here is what they have to say:
"Mount your Arlo camera at least 7 feet (2.1 meters) above the floor or ground, angle it slightly downward, and place it within 10-15 feet (3.0-4.6 meters) of where motion is expected."
Source: https://community.netgear.com/t5/Arlo-Knowledge-Base/How-do-I-optimize-my-Arlo-Wire-Free-or-Arlo-Pro...
Regards,
Dave
5 REPLIES 5
trayes77
I read an article the other day, can't remember the site, but a security expert suggested to have a camera approximately 9ft off of the ground for effectiveness. Though the expert was talking in general and not specifically the Arlo/Pro. I have my Arlo pro about 8ft from the ground. I get motion detection about 10-15 ft from the camera and can hear speaker audio if I speak loudly. My camera is pointed as far down as the included magnetic base would let me. Hope this helps.
I like the lower ranges if the camera is hardened or protected.... BUT, for Arlo I use about 8 feet.
The height is sort of a balance between getting a good face shot ( esp if they wear baseball caps ) and putting the camera out of normal reach.
( use to install cameras for security )
But, I also recommend a short tether of 6" on the arlo camera if you use a ball mount... from the mount to the threaded hole on camera ( 1/4-20 bolt )
So if it is knocked, it wont fall to the ground.
Drocks523
I was thinking of either buying the ceiling mount or the outdoor security mount. Im thinking of installing it above my garage door as the 2nd floor bumps out 3-4 feet and and i think it would keep the camera out of the direct sun and weather. do you have any advice as to which mount is better and more secure?
The more secure mount is a threaded mount over the half ball and/or table mount
But I would recommend using a temp mount ( half ball / one screw ) till you are sure it is a good location before mounting a threaded mount which can use 3 or 4
Retired_Member
Not applicable
Drocks,
Regards,
Dave
