We went out of town camping for 4 days last weekend and left our son to come and go during the day and spend the nights at a friends house, and had a dog sitter in for the evenings. Oddly enough our Driveway camera, which is plugged in to an outlet in the garage, and still is, recorded nothing at all, even though it always does about 50 to 80 recordings/day. When I try to use live view it says maximum of 5 camera streams are supported simultaneously. please stop one stream before starting another camera stream.. The battery powered front door unit which has never worked well and only records 2-3 times/day and uses up a 22,000ah battery/week doing that, has recorded 40 or 50 times/day since we have been gone but hasn't killed the battery yet. Why am I getting the error of too many cameras and how do I fix it? Thanks
Today all is good, and the wireless unit that rarely recorded is now recording around 70 events/day, just like the hardwired unit. Thanks for all the replys!
Power cycle the base and see if that corrects the problem.
That did not work.
You will then need to resync your cameras.
One thing to remember when resetting (not power cycling) is to remove all devices from Settings, My Devices before readding them.
So I turned the base station off and on, tried syncing it to the hardwired unit even though they are about 15' apart, and it is working now. The odd thing is now the camera that has never recorded more than a couple times a day, even though it see's almost everything the other sees, is now recording 70+ times a day...and still eats up a 22,000ah battery in 3-4 days??
Update: Now that the hardwired camera is working again the other camera is not recording, but works as I can still use live view. Is it possible the hardwired unit is preventing it from recording somehow??
Remove all of the devices, factory reset the base and start from scratch.
If stilll no joy then I would contact support.
