Can I know when the Subscription Plan will come to Malaysia ?
Cause I have 2 different based station and may need to monitor 9 cameras is difficult.
VMB4000, VMS4530, Arlo Pro
For temp use, look into Granting access... it will not give all admin control but all 9 cams will appear in one prgm
Dear TomMac,
Thanks for advice, It was Great !
I am successful add on to the 2nd account and can monitor those 9 Cams. It's some limitation but it's good enough for me at this stage. Cheers
*Defferent is the Both "Custom Mode" Setting may go for single account to setup, else Arm or Disarmed it can be done on Both.
