It seems that I have lost both the adapter and cable. Can't seem to find a way to purchase them separately, though.
Any ideas?
The adapter is widely available from amazon or similar stores... you need a Qualcomm fast charge supporting adapter ( many < $15 )
Also many come with a cable.... tho the end is a USB micro, some of the cables won't fit due to the plastics the usb plug is molded in so you may have to test a couple at the stores where you can physically try like Walmart, etc ( test the LG/Samsung phone adapters ).( or as someone else did , trim his down )
If just running the camera without battery installed, any USB adapter over 1a at 5v should work.
BTW,If you buy a spare battery from amazon, it comes with the adapter and cable
- Add-on 2440mAh Lithium Ion battery.
- Includes an Arlo Pro power adapter and cable with quick charge technology.
- Designed for Arlo Pro cameras.
