Arlo Pro accessable without interent but over local network
  • 1 Reply
  • 2728 Views
bluepenguin
I currently have the base with a 1tb drive.  I would like to access the base on my local network only.  Not over the internet.  Is there away?
Thanks in advance.
kmiller8821
Luminary
Luminary
Thanks in advance.
If you are trying to access the recordings that you have on the external drive, simply unplug it and plug it into your pc.  You will see the file/folders/recordings on the drive and you can just play them.  Return the drive to the base when done.  If you're internet is completely down, you won't be able to access the base software itself until your connection comes back up but you can always access your recordings on the base.  if your arlo system was armed before your internet went down and you have USB recordings enabled, you will get those recordings but with the internet down you obviously won't get alerts and the recordings won't be saved to the cloud (even when service is restored).  Hopefully that answers your question, good luck.
