I am dealing with the exact same issues! Recroding some motion, but minutes later not other motion (when I know for a fact there was motion that it should have picked up!). Also, I noticed today I will get a notification of motion, but then the notification will disapear and there will be no recording in my library! This is the worst monitoring system if it is not picking up all detection! So many holes! I have noticed this has recently started in line with the update.
Arlo, what do we do?
"It depends." (TM)
A possible issue is whether you were using live view during or after a recording. Live view disables automatic recording but you can manually record.
The app shouldn't have any effect. It's the camera, base and servers - the app is just an interface into that system.
So what would be your suggestion to get all movement recording verse intermittently?
That could be due to camera position and/or sensitivity setting. Have you tried looking at the FAQs here for positioning and changing sensitivity?
jgerdat: Can we really say with certainly the app has nothing to do with losing videos? Clearly the app has the ability to delete videos. What if there was some odd behavior in the app that caused it to delete some videos? It may be improbable, but with a major re-write, I wouldn't rule anything out. That said, I also know it is extremely common for users to blame a new release for behavior that has nothing to do with the new release. We do much worse at connecting dots that are not connected in real life.
Picking up some motion and not others that are basically the same is what has happened to mine as well as knowing there should be footage (actually seeing the library preview) and then having the video not be in my library. I don't believe it's due to the app update, as I noticed it before the update occurred (approx 2 weeks ago) and well as yesterday.
Yer right, of course - stuff happens. However, the fact that not everyone is having the problem pretty much eliminates that as the source - but not completely.
