It is not possible to mount the camera with a rigid threaded screw mount AND attach a solar panel
  • 2377 Views
VernSB93110
It is not possible to mount the camera with a rigid threaded screw mount AND attach a solar panel. The receiver for a threaded mount is to close to the receiver for the solar panel cable. Anyone have a solution?
VernSB93110
Thanks. That worked. Simple. Done!
steve_t
Master Master
If you're talking about the VMA1000 mount, they replaced the plastic collar screw with a small one about a year ago I think. Perhaps you can get your swapped or contact support
This is what the new one looks like
or pull off the large plastic lock wheel and replace with a 1/4-20 nut  ( much smaller )
VernSB93110
