Is there a way to disable the siren feature?
  • 2 Replies
  • 7914 Views
KeyserS175
Is there a way to disable the siren feature? I don't want to accidentally set it off.
Yes...it is in the modes/rules...you must edit the mode to turn off
Use Settings, Device Order to put the base/siren at the bottom of the screen.
