Is the control feature for the siren under "alarm" in the mode category?
Hello, is the alarm the function button for the siren? When you unclick the alarm, does that mean the siren has been disabled? Also, when you want to enable the alarm and actually click on the pencil, I go in there to turn the volume down and save, but when I go back into the pencil, the option is back at the highest volumn. Why doesn't it save when I click save to the lowest volumne? Isn't there a way to disable the siren for good? No where in the AP do they have options for the siren. It just says Alarm and when you go in the function, I am wondering what I am doing wrong that it doesn't save. Please help.
Yes.
Yes.
Depending on what mode you're editing, there may be multiple Save selections you need to use.
