There are kits, likely the one that you have, that directly support 6 cameras on the free account. Did you try installing it using the model ID? That would activate all cameras in your account. No false advertising.
different accounts... OR you can upgrade your servcice level and get more rolling storage days with all cameras.
TomMac wrote:different accounts... OR you can upgrade your servcice level and get more rolling storage days with all cameras.
Thanks, that's unfortunate after spending $600. This was a great product until learning this information that is not on the Arlo site. Particularly with so many options for free, professionally installed hardware when subscribing to other plans.
Does anyone know whether its possible to link two accounts on the app? For example, if my wife had a separate base and camera set on her account, would she be able to see my separate base and cameras that I have granted her permission to (and vice versa)?
That is possible using the GRANT ACCESS in settings
This is a shame, I've recently bought set: Basestation + 6 cameras. On the box it cleraly states (without any small print): Free 7 days cloud storage. Only when setting up you're informed this is only for 5 cameras. False advertising?
Haven't tried yet - 2 cameras are still charging, and I'm stuck with "firmware unable to download" problem. Will update when I have everything working and let you know. If it will indeed work then that's great news, though I was made believe by Netgear that it will not be the case (I wish I was alway wrong like that).
If yes, then great, but why does Arlo state that it's only up to 5 cameras?
If no, then why is it being advertised that way?
I would want to encourage Arlo to post clearly what the policy is. We should not have to go to a forum to find out the details of cloud policy.
It's been stated here that the specific 6 camera sets are supported under the free plan. I suspect that the box also says this but I haven't seen one. If you don't buy the specific package that has 6 cameras in it you will always be limited to 5 cameras for the free plan.
TomMac just responded to another post of yours with much of this information. I'll just refer you to that post.
It's all in the FAQs and documentation on this site in the Support area. I don't believe the 6 camera system is addressed since it's a special product with supporting documentation inside.
