  • 3882 Views
jsrau01
Is it possible to use multiple smart phones and a computer for one base station and if so, how do you set each of them up?  For example, will each require a separate e-mail and separate password?
steve_t
Master Master
If you install the app on each device and use the primary login, each time you login in, the other person logged in will be logged off automatically. If you set up other people with "Grant Access" then everyone can be logged in simultaneously I think
To be clear, you don't create separate accounts for any devices but just use one. As Steve said, you can have multiple simultaneous logins by using the guest accounts if that's the issue.  Only one can control a camera at a time if using live view.
grandpawmoses
I obtained multiple free Gmail accounts for the additional tablets/smart phones and only granted them limited access. Now all can be logged at at the same time without the others getting logged off.
