  • 2918 Views
Dadunn
Arlo suddenly will not recognize my email. Says it is invalid. My wife can access it on her phone with the same email address.
Dannybear
With the partners phone using your credentials, check if your phone is trusted under the 2FA list in the profile settings.
Also check that your phone is not using the community forum credentials instead of the arlo login.
Have you tried deleting and installing the app again?
Dannybear
Dadunn
We have uninstalled and reinstalled twice without luck. We will try your other suggestions tomorrow and will let you know. Thanks
Dadunn
Thanks for your help. We were able to get in.
