Both cameras working fine for 2 years now, however i now an getting intermittent sound on both cameras similar to a morse code noise, very annoying, have all required internet speeds
Sounds like some form of interference....
Tho there was a sound bug a while back, it was fixed by either a FW or hardware change.... have you put in a note to Arlo Support?
Keithw8750,
To add on, have you tried any trouble shooting steps with the cameras and base station?
Same issue...... sound is very choppy but only on the live view. My recordings are fine.
Crbjr62,
Is this a new issue or intermittent? What speeds do you get from your ISP?
Newer issues
20 mbps internet service.
Had these cameras up for over a year..... never had this issue before.
Is it always in one direction, that is, from you to the camera or vice versa or is it bidirectional?
Degraded video quality, choppy video, and/or choppy sound has been reported in the Arlo Beta program by myself and several others. We provided samples and now a bug incident has been opened with the Arlo devs. So they are now aware and agree something isn't right. Hopefully they straighten it out soon.
