  • 8 Replies
  • 3721 Views
  • 6 In Conversation
Keithw8750
Both cameras working fine for 2 years now, however i now an getting intermittent sound on both cameras similar to a morse code noise, very annoying, have all required internet speeds
8 REPLIES 8
Sounds like some form of interference....
Tho there was a sound bug a while back, it was fixed by either a FW or hardware change.... have you put in a note to Arlo Support?
ShayneS
Keithw8750,
To add on, have you tried any trouble shooting steps with the cameras and base station?
Crbjr62
Same issue...... sound is very choppy but only on the live view. My recordings are fine.
ShayneS
Crbjr62,
Is this a new issue or intermittent? What speeds do you get from your ISP?
Crbjr62
Newer issues
20 mbps internet service.
Had these cameras up for over a year..... never had this issue before.
Keithw8750
Its a new problem which only affects live feeds, recorded videos are fine, i have 36 meg download and 10 upload speeds, it is however impossible to use the 2 way talk function due to interruptions
Is it always in one direction, that is, from you to the camera or vice versa or is it bidirectional?
pc2k17
Hero
Hero
Degraded video quality, choppy video, and/or choppy sound has been reported in the Arlo Beta program by myself and several others. We provided samples and now a bug incident has been opened with the Arlo devs. So they are now aware and agree something isn't right. Hopefully they straighten it out soon.
