Thank you - I got this to work!
The first thing you have to do is split the cameras up from the default of (all cams ) armed
Use ADD A MODE to make a new mode for cam A ( call it front )
Now you can have A armed all the time ( using that mode when you are home in geofence ) and use the ARMED mode for both cams A & B to be ARMED while away in geofence
read this
and this
Thanks for the response. So, I played around and was able to get this setup. However, lets add one more complication. I have a third camera in the backyard that I only want armed overnight (schedule). So "away" mode stays the same as they are both armed, but the "home" mode currently only keeps the front porch camera active. Is it possible to add to the thrid camera on a schedule to this "home" mode?
Thanks again.
Thanks again.
Create 2 new modes 1) for the third camera and 2) the front and back
You will now have to schedule the cameras as wanted for the time allowed and use schedule in the HOME Geofence
