Is it possible, or will we ever get to set the mode per camera? I have one camera that I just want to use for monitoring things. I don't want a notification or to record. I don't have the option to turn those things off unless I make it unarmed. But I can't do that with just one camera.
Have you looked into custom modes ( ADD A MODE )
most of the time the cameras MUST be split up from the default of Armed ( ALL ON ) to individual cameras, then you can operate just one or more at the same time.
Exp; cams A, B, C
can be split up to ( using custom modes )
A
B
C
AB
AC
BC
ABC (default )
Exp; cams A, B, C
A
B
C
AB
AC
BC
ABC (default )
That worked perfectly. I didn't know you could leave camera's out of a custom mode and still see them, just not record them. Thank you for the help.
Now we just need them to make it so we can mask off specific areas from motion detection.
