Installed New Router (Nighthawk AC2400), Re-Connected Arlo & Everything Works OK, But Amber Light On
  • 2 Replies
  • 2244 Views
manh
Just installed new Netgear NightHawk AC2400, setup OK, everything works OK. My Arlo directly connected to LAN port 3 and has an amber light on, but all cameras working good. Why do I have amber light on router?
Please help
Manh
Which light is amber ?  ... they run;   POWER - Internet - Cameras
If it is the internet led, try a power button reboot of the base
The ROUTER port will have an amber LED since the connection from the base is 100Mbps. There's no need for faster since you simply can't swamp the connection between the base and router even with all cameras streaming at once. Same thing with the USB port - it's 2.0 since there's no need for the extra speed of USB3.0,
