Why does my camera night infrared come on when I have the camera set to off?
My pros are triggering on motion and sending emails but not providing push notifications. Using iPhone and push enabled. Actually getting push notifications from Arlo Q but not pros since firmware updated today?
I saw that Smart option there on the web. I just ignored that thing.. I already knew that's trouble right there waiting.. for now at least.... Right now, I'm still getting all the notifications...
Unfortunately does not function that way. Only pushes for person, emails for both.
Arlo Q currently always pushes if snapshot set even when push is not set.
So I get push notifications from Q when set to off and don't get push notifications for Pro when set to on.
Go figure .... the adults are not in charge yet!!!!!
Arlo...Arlo...Arlo
Are u using smart?
Not an issue here.. I'm getting too much notification coming from wind, sun and occasional loud noise.. lol.. All good, I know it's working...
When I turn off live I can still hear the audio running. I have to reboot the base from a computer. It won't reboot from my smartphone when I go live. How do I fix this piece of crap?
What is this "smart" option? I've had my arlo pro for seven months and thought I knew the software interface, but never heard of this feature. Please explain.
Yes, I've had this problem too. Sometimes the cam catches a cat, but at other times it misses an adult human. It appears to be random, but what a _bug_!
Re: New firmware
I hate to burst anyone's bubble, but my cam has drained its battery to 50% in two days after the new firmware was installed. That's approximately the same as before the firmware that was supposed to fix the May 15 problem.
I have a suggestion for the developers: add a battery charge tracking feature as a graph (charge held v time). Every smartphone has one. Surely its a simple implementation, and it would save a lot of time when talking about battery drainage in this and other forums.
Thanks paddos your a life saver or should I say a battery saver..lol.
I'm stumped. A few days ago I reset my base, made sure I have the most updated firmware, changed the batteries, and reset my notifications so it would send me a text and email when my camera catches something. I tested it and it worked ONCE and has not worked since (not capturing movement and therefore not sending any notification). Battery life seems ok though. WTF is going on?
@JamesC. @DawnM
Really???? Was this issue/s not reported on field test?
More info on notification "bug."
Tried setting smart slides either both on or just motion on and people off. When both on both person and motion sent email but only person send push notification. Camera set for both. When person slider off and only motion on, again no push notification but did get email. Soooooo .... appears latest change has an issue with sending push notification on motion when set regardless of smart setting. Using iPhone 6s.
Pls confirm you can replicate issue. Appears others on this thread are seeing same defect. Sensitivity with the battery firmware is noticeably lower as well.
One step forward and two back with every release.
