  • 5 Replies
  • 3219 Views
SailorBill
I've read the Incompatible Charger Error threads and it's blamed on moisture, etc. but I've had my Arlo Pro setup for a year and every single time I go to charge my cameras with the supplied charger and cable the error pops up and  it requires multiple attempts to get them to connect to the charger. Something else is wrong. It isn't moisture. Don't worry about me, I'll keep plugging it in and unplugging them until they connect and I'll be fine, but something else is going on other than "User Error".
5 REPLIES 5
ShayneS
SailorBill,
Have you tried contacting Customer Support regarding this issue? I have attached the link here for you - Arlo Tech Support
wwb_1
Definitley something going on with arlo backend/software. I have 9 cameras and am getting this error message as well now!
ShayneS
wwb_1,
Are you receiving this error with all you 9 cameras or is this isolated to a single camera?
wwb_1
Yes on 4 at my current location. The charger and cord being used, charges my cell phone just fine!
ShayneS
Due to the amount of issues described, I suggest contacting customer support regarding this issue? I have attached the link below for you - Arlo Tech Support
